Home > Puma (Tdci) > Removal of front wheel arch liner..
Page 2 of 2 <12
andy63
Got it all back together today.. Replaced the vacuum hoses to the brake and clutch servos as well.. In yellow,, 😎..
The non return valve in that line wasn't working, so that's why I was loosing vacuum so quickly after shutting down..
I also got a coat of white on the inside of the wheel arch liner I had off.. Lightens up the depths when you are peering down..
I'll do the other side the same one day👍😂..
Just need to take it for a drive and make sure all is as it should be..
Post #1035097 18th May 2024 3:25pm
Page 2 of 2 <12
