Home > Technical > 200 TDI - strange noise
BenUK1978
United States 1993 Defender 110 200 Tdi SW Fuji White
Hello - new to the forum - I have a 1993 110 200 TDI. Just had a ground up restoration at Nene Overland. Was stood for six months after that. Just brought over to the US and is making a whining / clanking noise from below the transmission tunnel. Does not affect performance. Please see audio on link below - starts at around three seconds on audio. Any help would be appreciated.
https://app.box.com/s/a14la6chykpo0e57vrsujrwuowvgt40t
Post #1034504 11th May 2024 11:56pm
julian
United Kingdom 1994 Defender 110 300 Tdi CSW Alpine White
You've checked the gear and transfer box oil levels and greased all the u joints?
Pay most attention to the transfer box.
Post #1034506 12th May 2024 5:49am
BenUK1978
Thank you - i will give that a go.
Post #1034534 12th May 2024 12:42pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
Also, make sure it isn't in diff lock. Physically check it isn't by jacking up a front wheel. With the other wheel on the ground and the main gearbox in neutral you should be able to rotate the lifted wheel. If it is in t-box diff lock you will only get a small amount of movement before the gear backlash is taken up.
Post #1034573 12th May 2024 6:03pm
