![]() | Home > Puma (Tdci) > Puma snorkel water ingress |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3354 ![]() ![]() ![]() |
Exactly right when it comes to diameter. A while back I spent a bit of time testing different setups with a magnehelic gauge, although this was for a wing vent with no RAI. I found that a 90mm hose was far better than 73mm, which you would expect. However a 102 mm hose didn’t improve things further ,which I didn’t. I suspect this was either down to the limitations of the filter/airbox or size of pipework after it. WARNING. This post may contain sarcasm. |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 756 ![]() ![]() ![]() |
The cabin air intake for the LHD vehicle is where the RAI intake will be installed, hence my question. Naka says they have a solution to relocate the fresh air intake for the cabin on the side where the old engine intake was located. Has a scoop like attachment with holes in the bottom of it to shed water, I reckon. Looks like I will save up for the Naka wing top RAI then. I wonder if fitting a Wolf-style side intake cover will hamper rather than help with cabin ventilation? |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 679 ![]() ![]() |
My thoughts and experience of fitting that snow/rain cover on the cabin air intake are that you need the fan on to get air to flow.. There is normally no natural flow without the fan.. But I have noticed now and again if I open a window, it must induce a bit flow as I can feel a bit warm air circulating without using the fan.. My observations anyway👍
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17679 ![]() ![]() ![]() |
The warmth you feel with a window open may not be coming from the heater. On my (non-AC) double-cab, opening a window seems to result in a lowered cabin air pressure and hot air being drawn in through the floor panel gaps and past the handbrake lever, the air being heated by the engine and transmission. I guess that some must be drawn in through the heater as well (my heater has a "snow cowl" and consequently no air whatsoever enters via the heater with the windows shut and the fan off).
The cabin ventilation on a Defender, just like everything else on a classic Defender, is quirky and unpredictable and does not behave in a way which is intuitive. Once you learn its foibles it is quite acceptable, but it takes some experimentation to figure out what it does! So much more fun and character than a modern vehicle. |
Yes it's definitely quirky.. I found it uncomfortable but two things have helped enormously..
No dpf😳... 🤣 And fitting one of the plastic deflectors that takes the hot air into the foot well.. Fitting the snow cowl definitely ment I always had to run the fan, but one day I noticed a warm air flow when the fan was off.. After a bit checking I realised I had the window down an couple inches.. I've got wind deflectors on and you don't really notice if it's only open by an few inches... Furthur playing confirmed that operating the window was altering the flow through the htr duct👍..I was rather surprised that the inside was as well sealed 🤣.. But I do use a bead of non setting mastic when the plates go back in👍 I'm pretty well used to it's quirks by now and can get quite comfortable👍🤣 |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2461 ![]() ![]() ![]() |
and the lack of side vents on the dash....That is something I do miss compared to other non-defender like models. Puma 110" SW
trevorg Member Since: 28 May 2022 Location: Aisne Posts: 52 ![]() ![]() ![]() |
My truck does not have a/c. I fitted louvred wing top vents to the cabin air intake (and the drivers side for aesthetics) and find the air flow through the internal vents is greatly improved possibly because when driving air is forced in through the louvre rather than drawn in as is the case with the standard flush fitting wing top grille. This air flow increases with the window slightly open. 2012 90SW - 2.2TDCI
jbcollier Member Since: 29 Apr 2024 Location: Edmonton AB Posts: 197 ![]() ![]() ![]() |
I have the Naka relocated air intake on a LHD Puma. It basically switches the two air intakes providing a simpler, more direct air path for the engine intake. The HVAC intake does not work quite as well but it does work well enough. I have noticed no change in power or drive-ability but I’m still using the stock air box — shortly to be switched to an Alisport air box.
My motivation for the switch was to get rid of the factory snorkel and replace a busted up factory air box. In winter, the snorkel causes snow to build up obscuring part of the windshield. |
