Home > For Sale & Wanted > [For Sale] Non-Landrover (VW Splitscreen/Isetta/D-type)
deaallen
United Kingdom 2012 Defender 90 Puma 2.2 SW Santorini Black
I hope posting these on here is okay? - I seem to remember seeing other posts by members advertising non land rovers, if its a problem let me know and I will delete the post.
I have a few different and quirky vehicles for sale:
1964 VW split screen panel van
Asking £18,000 ONO
51,726 miles / Left hand drive / original 1500cc engine, 4 speed manual
Imported from Italy & registered on 01/ 10/ 2001
4 different owners in the UK, 3 of which have been companies.
Originally off white but resprayed Black/Silver and wrapped in August 2004 to be used by Canadian/ American soft drinks distributor at surf, skate & snowboarding events.
Since 2008 has been in dry storage where it had MOT’s every year and any required work carried out.
Partial service history/ works receipts available
Has recently had a brake overhaul, including new brake master cylinder, new wheel cylinders, new brake lines & brake shoes fitted.
Comes with a fresh MOT which was carried out on 19/ 01/ 2024
1960 BMW-Isetta 300
Asking £15,000 ONO
34,000 miles / left hand drive
Just fitted a new fuel tap and steering damper. Original condition, 300cc engine, everything is running well.
There's some small damage on the body work on the left rear corner. (see last photo's - the bodywork is slightly bent away from the bumper)
Tax & MOT exempt, will put it through a fresh MOT before sale. Comes with one spare wheel.
Stardust replica Jaguar D-type
Asking £25,000 ONO
Built off a 1972 Ford Cortina donor using a "Stardust" Kit. Suspension is via oil coil springs all round with fully adjustable gas shock absorbers. The engine is a 2-litre Ford Pinto twin carb.
Dry stored when not in use. Starts, runs and drives well.
More pictures can be found in my Gallery or I can post more if required - just let me know what you'd like to see. .
All vehicles are located in Basingstoke, however I do have a recovery truck so I can deliver at your expense, if needed.
Any questions please ask Smile
Post #1032773 25th Apr 2024 7:40am
