Home > Puma (Tdci) > Air suspension and rear shocks |
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 485 |
You will probably have to use a front damper from someone like Fox with a extended 2" lift but be careful as a longer damper may over extend the airbag. If a robust top bush and washer something like the original thick washers used on OE Defender dampers is used it should prevent the damper pulling out of the bush.
23rd Apr 2024 9:52am |
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 809 |
Feel free to drop me a PM... I'm an approved VB installer.
I've often used the Fox Pin/Pin set up - but have had issues with the Fox dampers snapping pins (early version). Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
23rd Apr 2024 10:19am |
