Home > Modifications & Maintenance (L663) > Air Suspension Balancing for Camping Mode
heldentage
Germany
Hey all, has anybody any idea on how to use the air suspension for leveling the car for overland camping? As the L663 has all the information available and can control each tyre individually it should be easy to level (balance) the car instead of using the "good old drive-on wedges"?
Post #1031289 11th Apr 2024 4:54pm
Moo
Ukraine
I thought that they self levelled? Confused Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Post #1031293 11th Apr 2024 5:23pm
heldentage
Germany
Nope - not at all
Post #1031295 11th Apr 2024 5:31pm
J77
I assume he means he’d like more air on one or more corners to compensate for any gradient it’s parked on? 24MY 90 D250 HSE, Tasman Blue
Post #1031296 11th Apr 2024 5:37pm
WizzardPrang
You can use the Rear Height Adjust controls to raise or lower the rear of the car, which would help fore and aft balance.
 Current vehicle: 2020 Defender 110S
Gone: Defender 90 HT 200Tdi, Discovery Sport, Freelander 2
Insta: wizzardprang
Post #1031305 11th Apr 2024 8:58pm
Lightwater
Australia
A few blocks of wood. A bit like pencil & paper, getting back to the fundamentals! Visitor - Freelander owner
Post #1031501 14th Apr 2024 10:07am
stevemfr
France
I use the IIDTool for this - and have since we came out with the very first version.
It is still a little, how shall I put it, work intensive. We don't have a "one button" solution (...yet. But we may or may not be coming out with something - not tomorrow tho. Still busy with the G4). It's not nearly as work intensive as blocks of wood, rocks or even the foldable ramps people with caravans and motorhomes use, tho.
I have to check for the L663 to make sure of the procedure, but on the earlier vehicles:
- you put the EAS into 'build mode' to incapacitate the EAS
- lay your level on your sleeping surface (I use a phone app)
- and inflate each corner as needed with the 'test valves' function
When you are finished camping, you exit 'build mode' and the EAS functions as before.
I will check on the procedure (terminology - in earlier vehicles build mode was called transport mode) and post back here.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s,
2 FL1s and a L663 on the way
Post #1032171 19th Apr 2024 5:55pm
stevemfr
France
L663 is the same, the only difference is that the ECU/system is now called CHCM (Chassis Control Module) whereas in older vehicles it was the RLM (Ride Level Module).
Takes about 1-2 minutes to set the corner heights.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s,
Post #1032641 24th Apr 2024 9:09am
TexasRover
The problem with a block of wood is that you need to get out of your car, so that's not going to work. Then what if some mud would stick to the wood? You are snookered then!
I bet you did not think of that did you! Boomers always think they know best!
Post #1032652 24th Apr 2024 10:52am
Sideways
FWIW, that came across as weirdly aggressive!
Post #1032777 25th Apr 2024 8:11am
heldentage
Germany
Hey Stevemfr,
Thank you so much for the feedback / I also have been in contact with Powerful UK (Simon) and he also gave me the info, that Gap Diagnostics with the IIDTool BT G4 is working on something.
Just a question: are you a customer of Gap or do you have any (in-)direct link to GAP?
Many Greetings
Post #1033598 2nd May 2024 10:09am
stevemfr
France
There's a reason for the signature. I've been a part of GAP since the beginning... Razz
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s,
Post #1033668 2nd May 2024 9:19pm
DFNDER
Australia
For the L319 platform, a Czech company built and sold the X-Lifter, a plug and play module to let you customize ride heights, and add custom settings, etc. It also allowed individual corner adjustments to get the vehicle level, regardless of surface (within limits of course). Emailed them late last year, Jan told me they are working on a solution for the L663 platform. It's a "one button" solution for the L319, seems to me not that hard to adapt for the L663.
https://www.xlifter.com/?gad_source=1
Post #1033674 2nd May 2024 11:57pm
heldentage
Germany
Hey Steve,
Thanks again for your feedback - much appreciated / if you have any news or an update on this topic I would be really greatful.
Thank you in advance.
Post #1033894 5th May 2024 6:06pm
Mark1107
United States
We’re all excited if GAP can do 4 corner leveling and skip the painful LLams surgery abomination… 2022 Defender Trek Competition 110 collectors edition!
2020 Defender 110 P400 Full Explorer Pack 7 Seater HSE Fuji White(sold)
2020 SVO Range Rover L405 Full Size Spectral Blue Chromaflair
2014 Range Rover L405 Autobiography Full Size Aintree Green
2014 Dodge Viper GTS Stryker Green
Post #1034249 8th May 2024 9:50pm
