![]() | Home > Td5 > Relay wiring |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 508 ![]() ![]() ![]() |
Both Puma and TD5 heated seat switches are positive switching between pin 1 and pin 4 - and, yes, it does make a difference, because the background and tell-tale illumination are LEDs, which are polarity sensitive.
You only need a fuse on the supply to relay pin 30 ![]() Click image to enlarge . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
110Matty Member Since: 20 Apr 2023 Location: Somerset Posts: 140 ![]() ![]() |
Brilliant, thank you @paulMc 👍
