![]() | Home > Td5 > OEM switches with Rimmer seat heating kit |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 965 ![]() ![]() ![]() |
Which OE switches are you asking about? Early or post 2002??
I found some two level stage (high / low) which are similar to the OE on my 1999 build on eBay. If you use a SPST (on /off) you’ll only have one setting with an early style switch. Good luck ![]() Click image to enlarge 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
110Matty Member Since: 20 Apr 2023 Location: Somerset Posts: 140 ![]() ![]() |
Hi there, thanks for the reply.
It's the same switch as used on the Freelander 1, Discovery 2 and Defender TD5. They are on / off only I believe? A bit of an update and big bonus though, the seats fitted are Mazda RX8 leather bucket style and the drivers side has electric adjustment and both are heated with elements and connectors fitted (but not wired up). I'm discussing on another forum actually and it seems i can fuse each seat with 10 amps and fit 20 or 40 amp relay, so just as well go 40 amp and try to find a timed one. That's my next bit of research, unless anyone can help first? Cheers, Matt. |
