Home > General & Technical (L663) > Side step fitting |
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1183 |
Before you get them fitted, read this .....
https://www.defender2.net/forum/post1008571.html#1008571 for this accessory ....... buy genuine. |
11th Mar 2024 4:52pm |
DrRob Member Since: 29 Mar 2017 Location: Hampshire Posts: 215 |
The ones from www.sidesteps.co.uk are made of much better materials than the £200 jobbies and don't need any trims removing.
Cut the apertures on underside of plastic trim, fit brackets, fit steps, done. Tea and medals MY25 90 D350 X-Dynamic HSE in Silicon Silver and coil sprung 1974 Series 3 Lightweight = "Millie" Many Range Rovers and Land Rovers over the years 😂 1949 80" - still in family since 1975 |
12th Mar 2024 10:15am |
Geedubu187 Member Since: 10 Jun 2015 Location: North West Posts: 101 |
thanks for the replies but have already got the sidesteps so just looking to get them fitted, if need be then will get another set if and when these deteriorate.
Graham |
12th Mar 2024 4:59pm |
