Home > Td5 > TD5 ECU repairs
MadTom
TD5 ECU repairs
During last winter I have spent some time with non working TD5 ECUs and as a result I made schematics of the ECU internals and I think, I understand how the hardware of ECU works. Here are some pictures and videos of ECU testing with crank signal simulator: https://www.rajce.idnes.cz/ok2mtm/album/td5-ecu-oprava-repair
I was able to repair quite fast 10 ECUs I had here as death on arrival for long time. Problems were different, often broken passive component, but never problem with the two big capacitors.
To simulate the crank sensor signal I use basic Arduino board with short and simple code. For first test runs I was using spare set of old injectors, but it is quite noisy, so I made some solenoids with screws used as cores and to make the running ECU audible a visible.
Non repairable are ECUs totally burnt (small burnt through hole is still possible to repair) or drowned for long time. Bot of these results in too big much damaged parts.
With schematics faults like TOP SWITCH are possible to diagnose and repair. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #1027263 8th Mar 2024 11:43am
MadTom
And some more pictures:
Signal from crank sensor simulator.
Burnt ECU - this is not repairable.
Home made test bench.
During test the ECU is powered from old battery, because it has no connection to ground and makes some measurements simpler. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #1027264 8th Mar 2024 11:50am
Martin
Site Admin
Very impressive Bow down  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1027265 8th Mar 2024 11:53am
Prisk81
Italy
Hi, do you have problem some times with rpm 0, so not start? In diagnosis I have 0 rpm in cranking but with oscilloscope on ecu pin signal is good...
Post #1060392 12th Feb 2025 6:05pm
TexasRover
Are they robust generally? I have a 15p Td5 and manage to get my hands on a free 10p ECU which I keep for emergency spare, i understand this would get you home.. (I have a nanocom)
Probably should be looking for the correct ECU, but look a bit pricy?
Post #1060393 12th Feb 2025 6:28pm
Prisk81
Italy
I try to repair my ecu before search another one.
Post #1060412 12th Feb 2025 8:41pm
MadTom
For "emergency" run of TD5 engine, you can use any engine ECU, just "solve" immobilizer - pair it with car of "remove" from ECU. In one car (Defender TD5 or Dicsovery 2 TD5) you can pair more than one engine ECU, so after this basic "preparation" it is just plug and play. No need for any diagnostics use.
All TD5 ECUs use the same hardware for controlling injectors. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #1060522 14th Feb 2025 8:59am
jonny
If you are keeping one for emergency use (eg. overlanding), there's probably a few more steps you should take - copy the injector settings over etc.
But 'cloning' one ECU to another is fairly well documented so if you were going to the lengths of having a spare ECU you may as well clone it totally when you disable the immobiliser..
Post #1060533 14th Feb 2025 11:09am
Prisk81
Italy
Thank you. I have found the resistor/ fuse connected with injectors gnd blown,it measure 1,6 kohm now I must known value of it and after see for other component that can have damage
Post #1060538 14th Feb 2025 12:36pm
