Home > Puma (Tdci) > BRITPART !!!
bunnyman
England 2009 Defender 90 Puma 2.4 HT Galway Green
BRITPART !!!
Hi all are brittpart rear shocks any good ??
Post #1026391 29th Feb 2024 6:02pm
Howard
United Kingdom 2012 Defender 110 Puma 2.2 PU Alpine White
I had two rear Britpart shocks break on my 110 and replaced with KYB (Japanese) which have proved to be very good.
Post #1026426 29th Feb 2024 11:01pm
TexasRover
If your are short of cash... They are easy enough to change if they were they to fail. Probably will be just fine for years and years. There is always the possibility that what you buy is from the same factory of something OEM
Post #1026433 1st Mar 2024 5:54am
bunnyman
What manufacturer makes the Landrover ones ?
Post #1026444 1st Mar 2024 8:27am
kenzle8a
Boge from memory make the land rover ones
£80+ vat for a genuine one isn't bad
https://www.island-4x4.co.uk/rear-shock-ab...42207.html
Post #1026447 1st Mar 2024 9:08am
hornet
To be honest, I would avoid Britpart wherever you can. Last time I fell in again and bought an ignition switch in december that didn't spring back after 10 starts and I had to switch off the starter manually!
Post #1026471 1st Mar 2024 1:56pm
To me, Britpart is what you might call the "supplier of last resort".
I only buy Britpart if (a) absolutely nothing else is available or (b) someone has kidnapped my family! Laughing
Post #1026476 1st Mar 2024 2:47pm
MK
I would say genuine are the best, even a bit overkilling for on road use. Puma 110" SW
Post #1026493 1st Mar 2024 4:20pm
Dinnu
If my family is kidnapped, might be able to afford the premium brands. No way I am paying any ransom Rolling with laughter
So for now I try to shop wisely. Not all Britpart is S#!tpart. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1026495 1st Mar 2024 4:28pm
Mdm
not worth fitting them as they won't last 12 months even on road use.
mate fitted thm last year and 3 out 4 had failed within 8 mths std spec 90 sa well circa 7k on them
Post #1026767 4th Mar 2024 9:15am
Oldowner
In Britpart’s defence, I fitted their Cellular Dynamic dampers to an older 90 of mine as it was the only items I could obtain in the timeframe I had to do it, intending to swap them out for another brand shortly after; I was actually very impressed with them, they have been fitted for seven years now with no issues and seem very good, perhaps a little harsh over rough ground but for road use they were excellent. Even the paint finish has held up really well.
I fitted Fox 2.0 to my Puma 90 which was parked up outside and unused last summer, one of the damper rods has serious corrosion already having done zero miles and Fox will not warranty them as although they have only been fitted nine months, I purchased them 18 months ago. On the plus side they are rebuildable so it is on it’s way to have a new damper rod fitted at my expense.
If on a budget, Girling ones seem good at around £30 each, although I don’t have any long term experience of them.
The budget Britpart dampers with the plastic shrouds and foil wreath decals are utter junk however.
Post #1026895 5th Mar 2024 4:44am
MarkBrown
Wales 1983 Defender 110 Other HT Auto Keswick Green
I bought a set for my rebuilt 110. After about 7k miles they had to be replaced, due to no oil. I know they're cheap but that's ridiculous! Absolutely rubbish.
Post #1026899 5th Mar 2024 7:01am
