Home > Technical > Defender door trim clips help please
sasdiscos
Hi all.
My doors have the white clips embedded in the door cards. Then another white receptor in the door frame. A small black clip then slots over the door card part and located within the receptor.
The only part number I ca find is MXC1800.
I ordered them from eBay and they are too large for the clips on the door trim side.
Where there different ones?
Thanks. Steve.
Post #1026229 28th Feb 2024 7:43am
sasdiscos
I have found MWC9134. I think they may have sent me the wrong clips. Looks like MXC1800 are the correct ones.
9134 are larger.
Steve.
Post #1026230 28th Feb 2024 7:53am
Cragster69
Scotland 2007 Defender 110 Puma 2.4 CSW Cairns Blue
Wasn't sure what year of Defender you have but you should be able to find the parts and numbers from the following list of diagrams
https://www.lrworkshop.com/diagrams/land-r...-trim/trim
EZM500050 seems to be a common fastener part number across all models and might be what you are looking for? https://www.lrworkshop.com/parts/EZM500050 Craig.
“Don't believe everything you read on the internet.” ― Abraham Lincoln
www.scotgrc.co.uk
Post #1026241 28th Feb 2024 10:44am
sasdiscos
Mxc1800 are indeed correct.
They sent me the wrong ones.
Thanks.
Post #1026824 4th Mar 2024 5:44pm
