![]() | Home > For Sale & Wanted > [Wanted] Swing away wheel carrier, led lights |
alwoodley72 Member Since: 14 Mar 2010 Location: salisbury, wilts Posts: 726 ![]() ![]() ![]() |
Hi there,
Just bought a 90 as a project, it’s got no lights and set up as a comp racer..! Will need a full ish set of led coloured lights, headlights too, anything considered really, on a budget so no £400 noldens I’m afraid. Also need a swing away wheel carrier, it is a pickup but I’ll be converting to a side open tailgate so needs to be of the door opening type.. anything considered again… In Wiltshire but I get around a bit… Cheers Alex 98 300 tdi 90 project 94 Range Rover vogue 4.2 lse 79 911 sc 08 130 double cab utility |
Bumpy bump
Pace Member Since: 19 Mar 2021 Location: Somerset Posts: 85 ![]() ![]() ![]() |
I have a set of the Wipac LED lights (https://rimmerbros.com/Item--i-LL1781DELUX...gJFSfD_BwE). They were on one of mine for two years prior to removal back to standard when I sold the truck.
They're in the box, condition is almost as-new. I'd want £100, they're located near J25 M5. Does that work? |
Pm sent to Pace..^
Still looking…
Still looking…
Still still looking, anything considered..
Cheers alex 98 300 tdi 90 project 94 Range Rover vogue 4.2 lse 79 911 sc 08 130 double cab utility |
LET'S OFF-ROAD Member Since: 05 Jun 2022 Location: Green Laning Posts: 66 ![]() ![]() |
![]() Last edited by LET'S OFF-ROAD on 26th Apr 2024 7:47pm. Edited 1 time in total |
I’d love that, but fear it’s out of my budget!…
Let me know… Cheers alex 98 300 tdi 90 project 94 Range Rover vogue 4.2 lse 79 911 sc 08 130 double cab utility |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3709 ![]() ![]() ![]() |
I think I have a swing away wheel carrier, I'll check tomorrow. 130's have feeling's as well you know
Thanks!
Sorted for lights, just the wheel carrier now..
jcw Member Since: 11 Sep 2016 Location: Gloucestershire Posts: 168 ![]() ![]() ![]() |
I have a brand new Mantec one that’s surplus, I’ll PM you
Landy addict Member Since: 03 Dec 2022 Location: Argyll Posts: 75 ![]() ![]() |
I have a used one of these https://www.lrsoffroad.co.uk/defender-whee...sel04.html I took it off my defender when I started full restoration decided to put a new ORE carrier on. Post might be the biggest issue, I can send photos if you are interested.
Many thanks, pms sent..^^
Cheers. Alex 98 300 tdi 90 project 94 Range Rover vogue 4.2 lse 79 911 sc 08 130 double cab utility |
