![]() | Home > Td5 > TD5 Injector Harness - Replace? |
Craig772 Member Since: 23 May 2022 Location: Cannock, Staffordshire Posts: 73 ![]() ![]() ![]() |
After finding oil at the ECU I cleaned it up and ordered a new injector harness and gaskets. I was expecting to find a evidence of oil in the plug but it looks clean to me.
Would you re-fit the harness and keep the new part as a spare or fit the new harness? Stopping for coffee and biscuits. I am likely to fit the new part to be safe but this isn't what I was expecting to find. I thought I'd find oil in the plug as per at the ECU end. ![]() Click image to enlarge https://www.instagram.com/roxi_defender90/ |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5839 ![]() ![]() |
Fit the new, but only after sealing the end first.
New harness fitted, gaskets and isolator grommet things. I sealed the harness so hopefully that's that. Just clean out the ECU socket every so often until the loom dries up.
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2109 ![]() ![]() ![]() |
A job well done!
