![]() | Home > Technical > 7/16 A/F tap size |
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 ![]() ![]() |
To those who understand the imperial system of measurements (I certainly don't
![]() Can anyone tell me the tapping size for a bolt that uses a 7/16 sths spanner. Bolt in the thermostat housing of the series III 2,25P. not sure but think it is UNF. Thanks James Puma 110 - gone Series III 1973 - going strong |
foz.in.oz Member Since: 31 Jul 2008 Location: Gladstone, QLD Posts: 64 ![]() ![]() ![]() |
I beleive that would be a 1/4" UNF. It has a finer thread than an M6? If coarser it could be Whitworth. Land Rovers are an addiction. Toyotas are for quitters.
WWW.CQLROC.ORG |
Bosun Member Since: 21 Jul 2008 Location: Great Berry Posts: 141 ![]() ![]() |
Don't forget UNC!
was UNF - thanks and spot on.
I grew up with the Metric sustem and can't fathom how anyone uses such a complex set of numbers in the Imperial. Each to their own I guess ![]() Cheers James Puma 110 - gone Series III 1973 - going strong |
everyone makes mistakes
![]() Series III 1973 - going strong |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5082 ![]() ![]() ![]() |
yes going metric ![]() |
10mm = 1 centimeter
1000mm = 1meter 1000meter = 1 kilometer what more can I say ![]() Series III 1973 - going strong |
1 billion microns = 1 Km ![]() |
Are you all sure it isn't a Whitworth thread
![]() 1968 1/32 scale Britains 109 Pick up. |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 ![]() ![]() ![]() |
Simples compare the millimetres .com ![]() |
