Home > Wheels & Tyres (L663) > TPMS sensors
lightning
TPMS sensors
l've just bought a set of new take-off steel wheels with tyres for a bargain price, they seem to be selling for less than £100 a wheel which is barely half the price of the tyre.
My question is, how can l tell if the TPMS sensors are fitted, are they part of the valve? Can they be transferred between wheels?
Post #1024606 13th Feb 2024 1:40pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
The TPMS sensor is part of the valve but it's the part that is inside the wheel so it's difficult to tell from the outside whether you have them fitted or not. At one time the valve stems being metal would indicate that they had tpms valves fitted but now you can get sensors with black rubber stems also Confused You can take the dust cap off and there may be TPMS marked on the brass section if not the only way to be sure would be to either break the bead on the tyre and have a look or fit one of the wheels, take the car for a short drive and see if it picks the sensor up. The sensors can be changed between wheels Thumbs Up Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #1024608 13th Feb 2024 2:05pm
SteveG
2005 Defender 90 Td5 CSW Belize Green
I assume you’ve bought a take off set, in which case they should come with the sensors as you’d have to remove tyre, remove TPMS valve and fit a non tpms valve to remove them. Very unlikely by most people swapping them for larger alloys.
Easy to spot in person if they’re still there. When you fit them, just reset TPMS and after a few miles they’ll appear.
Post #1024609 13th Feb 2024 2:06pm
LR Nuts
If the TPMS throws up an amber light on the dash, it's an MOT failure.
Post #1024616 13th Feb 2024 3:36pm
