Home > Off Topic > Flexi Brake Lines
walfy
Flexi Brake Lines
I have a project in the garage that I'm slowly working on. It's a Polaris 425 6x6 quad with tipping rear bed.
It's sat for a few years, the frame is very good but the tipping box is shot. Needs a new one built.
But I am struggling with, every now and again when I turn the ignition off, the engine continues to run, I then block the air intake and it stalls out. Would it reasonable of my thought process to think it's the ignition switch that is faulty?
Secondly, the farmer who had it before me couldn't get any pressure in the brakes so fitted new calipers but in the process rounded off every brake union in the whole system. There are only flexi lines and Ploaris doesn't make/stock these anymore. So I'm after making them myself.
Is there a sensibly priced kit that would facilitate me in making flexi pipes? Google isn't helping at the minute. 110 D250 SE HT
110 USW SOLD
Polaris RZR 900XP SOLD
Post #1024353 11th Feb 2024 5:19pm
Ianh
Have a chat with Pirtek , they have a branch in Westbury https://www.pirtek.co.uk/service-centres/westbury/, they stock many parts and can make bespoke hoses for most hydraulic applications.
Post #1024357 11th Feb 2024 5:43pm
walfy
Many thanks. Hadn't thought about them. I thought they were always for big industrial/plant applications 110 D250 SE HT
110 USW SOLD
Post #1024358 11th Feb 2024 5:50pm
Bps
Brake lines
Try pioneer 4x4
Post #1024363 11th Feb 2024 6:03pm
walfy
With the quad being so old I have no idea of the thread pattern for each union.
I had hoped to either biuy a kit that allows me to make my own unions or take it somewhere and just give them my current lines and they just give me a new set that I could just fit 110 D250 SE HT
110 USW SOLD
Post #1024365 11th Feb 2024 6:11pm
John P
United Kingdom 2012 Defender 90 Puma 2.2 SW Corris Grey
Why not get your own built, by someone like this? https://auto.helperformance.com/custom-car-braided-brake-lines
Post #1024369 11th Feb 2024 6:30pm
walfy
@ John P. Not knowing what Polaris used in the late 90's is the issue. If I could be 100% sure what thread they used it would be easier. 110 D250 SE HT
110 USW SOLD
Post #1024373 11th Feb 2024 6:38pm
John P
What about getting a gauge to check?
https://www.mfcp.com/our-blog/bid/76568/Th...rake-Lines
As part of my tap&die set I have a metric gauge to check thread pitch. Maybe you can get something to check the thread pitch and diameter? I suspect this won't be easy, as I had a job trying to identify some non metric threads. Big Cry
Post #1024380 11th Feb 2024 6:54pm
walfy
Thread gauge is a great idea. Found this company Car Builder Solutions. They sell a gauge for £6. So thats my first order and go from there 110 D250 SE HT
110 USW SOLD
Post #1024387 11th Feb 2024 7:19pm
landy andy
“Would it reasonable of my thought process to think it's the ignition switch that is faulty?”
Should it be stopped via a fuel cutoff solenoid? I think it probably is, and that is where I would start my checks.
Post #1024388 11th Feb 2024 7:19pm
walfy
Would something from the 90's have such a cut off solenoid? 110 D250 SE HT
110 USW SOLD
Post #1024390 11th Feb 2024 7:20pm
donmacn
Certainly 300Tdis have one on the back of the fuel pump, and I’d imagine the 200s as well. It should be an easy enough thing to check. At one point my car started ‘hesitating’ - the fuel solenoid wire was barely connected. Crimped on a new connector and the problem disappeared completely.
In the Bosch VE pump (tdis at least) the solenoid allows the engine to run. I guess it could also be configured to cut the fuel delivery on power off…? But the key term there is ‘guess’ - sorry I hadn’t realised this wasn’t a Landy Embarassed Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #1024411 11th Feb 2024 9:07pm
landy andy
Yes. And the more basic the application the more chance of having one.
Post #1024412 11th Feb 2024 9:16pm
LiftedDisco
If you need some flexis making up, try Furore Products - They have made bespoke flexis for me in colour of choice and are cracking folks…
Post #1024414 11th Feb 2024 9:53pm
NickMc
Try David at llama 4x4 01952 825732 he makes brake hoses to order Thumbs Up
Post #1024423 11th Feb 2024 10:59pm
