Home > Puma (Tdci) > 2011 Defender 2.4 Puma cranks but will not fire.
Page 2 of 2 <12
Ianh
Glad it’s solved.
However , just for clarity, that’s not an issue with the immobiliser, I.e the 10AS. It’s an issue with the immobilisation circuit between the 10AS and the engine ECU. On the 2.4 the single wire goes via the instrument cluster (IC) and within the IC the PCP solder connections can fail, breaking the circuit between the 10AS and engine ECU. As you rightly say this was addressed in the 2.2 Puma’s where the wire does not go via the IC.
Post #1029837 30th Mar 2024 2:13pm
Sparke
United Kingdom 2011 Defender 110 Puma 2.4 HT Alpine White
Thanks for the reply Graham, I am thinking mine is the high pressure fuel pump and sensors. Deep Joy.
Post #1030805 7th Apr 2024 8:11am
Page 2 of 2 <12
