Home > Maintenance & Modifications > Rivets for rear extension panel
WestCountryPete
Sorry if this has been covered before. I did a search and found lots of details on body cap rivets, but not the panel extension one.
One of my rivets went walkabout so want to replace it, but with one that matches the others. I don’t want to go through replacing them all and having a different type will bug the hell out of me! So my question is…
Can someone confirm the rivets used in rear panel extensions, between the rear door and rear arch of a 110? The ones that aren’t coated in paint and have angular shoulders. Is it RU612253, as on this diagram:
https://www.lrworkshop.com/diagrams/land-r...ings_44851
A point in the right direction would be much appreciated. Thanks
Post #1020259 5th Jan 2024 9:05pm
I can't help answer the question, I'm afraid, but for info those rivets were installed after the vehicle was painted and none of them would have been painted.
Post #1020264 5th Jan 2024 9:30pm
WestCountryPete
Well spotted…that was a typo Whistle
Post updated to reflect them not being painted. Thanks
Post #1020266 5th Jan 2024 9:32pm
geobloke
You need a 3/16" pop rivet and preferably the sealed versions. The part number you found is correct, but I could not get any so used RU612373L which are marginally longer but the same diameter.
Thumbs Up
Post #1020522 8th Jan 2024 1:00pm
WestCountryPete
Thanks for confirming I’m along the right lines - much appreciated. Order placed.
Post #1020854 11th Jan 2024 9:19pm
