![]() | Home > Technical > Wiper issue |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2122 ![]() ![]() ![]() |
Happy new year to you too.
There could be many issues as it’s not the most robust mechanism. It’s likely that the wheel boxes are worn, but it’s worth you searching ‘wiper fault’ or similar on here as there are many posts. Good luck 🤞 |
300TDi CSW Phil Member Since: 03 Apr 2016 Location: Bracknell Posts: 750 ![]() ![]() ![]() |
What model etc is it?
If it's like the 300tdi it may be the wheel boxes that have gunged up or worn to the point where the snake drive thing can't make them move. 1995 300 Tdi Epsom Green - It's a keeper. Wide Track Sankey- In bits- Gone to a new home M0XQS |
MarkBrown Member Since: 03 Oct 2022 Location: Mid Wales Posts: 530 ![]() ![]() ![]() |
I've just fixed a similar problem with mine. It was a broken drive cable, also the park switch was broken, again, but that's a different fault. There is a cable that runs from the wiper motor to the wheel boxes, which connect to the blades outside. I think that if these corrode the teeth inside wear off, but most likely only effect one blade. I don't know what the later ones are like, but I'm guessing that they're all broadly the same. The cable can be changed without dash removal, I doubt that the wheel boxes can. Assuming that the park switch is working, you should be able to hear the motor going back and forth. Hope this helps.
