Home > In Car Electronics > Mud stuff TDCi switches.
Rescue01
I’ve bought several of these switches for some lighting accessories in my 110.
Had a look today at the wiring diagram and have a (probably stupid ) question.
Here is the diagram.
There’s no numbers on the terminals so holding the switch in my hand with the terminals facing me should the icon on the switch be correct way up (this icon)
Thanks.
Post #1019419 28th Dec 2023 10:59am
jim4244
England 2007 Defender 90 Puma 2.4 CSW Zermatt Silver
Hi
Its a 50/50 question but logic would say "Yes"
Jim
Post #1019420 28th Dec 2023 11:01am
Rescue01
Thanks Spock Laughing that’s what I’m thinking. Tried calling them but they are closed till the 3rd.
Thumbs Up
Post #1019421 28th Dec 2023 11:07am
excossack
If you use a multi-meter in continuity mode and check pins 1 and 4 and you get either continuity with the switch pushed in or out then you will know which pins are which and work out the rest from there? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #1019422 28th Dec 2023 11:12am
Rescue01
Thanks for that.Electrics is not my strong point Thumbs Up
Post #1019423 28th Dec 2023 11:15am
geobloke
If they are like the other TD5/TDCI switches Mud sell then with the switch facing away from you but the right way up the pins go left to right (1-4). On these there is also one silver pin which is the earth pin and number 4.
These switches - https://www.mudstuff.co.uk/collections/mud...ront-light
Just looked again the AUX switch you linked to is like the above with 4 pins, not 5 as in the document you attached with the wiring diagram which is for genuine switches.
Post #1019426 28th Dec 2023 12:27pm
rallysteve
MUD switches are simple to wire
Pin 1 -Power in
Pin 2- Dashboard Illumination in
Pin 3-Power out
Pin 4 (Silver pin) -Earth/Ground. 02' 110 TD5 Double Cab Rebuild Thread
Post #1019437 28th Dec 2023 2:48pm
Rescue01
Thanks for all your feedback. All sorted Thumbs Up
Post #1019493 29th Dec 2023 6:16am
