![]() | Home > Td5 > Fuel pump whining / fuel gauge inaccurate |
First off, how irritating
![]() Second, before you fill to the max fix that breather hose in the rear wheel well, diesel will leak out of it if full and wheel well water and grit may enter through the splits as well. The worst case is if you ford deep water you might end up with a half tank of muddy pond water. As for the gauge not reading consistently and the fuel pump noise I would be thinking of checking connections and earths to begin with. If that does not sort the problem then I would be thinking that the fuel pump itself is at fault both in terms of the pump noise and the senders variable resistor. In which case only fit a VDO pump. TD5 life ![]() |
458GT Member Since: 22 Jun 2022 Location: Warwickshire Posts: 84 ![]() |
Thank you and I already informed the specialist re: VDO and they've advised they would only fit OEM or Genuine etc.
I will do so, although I had filled it up before I read the post but fortunately no diesel leaking anywhere. It was all a bit dirty under the chassis so have cleaned around the chassis amongst various areas and will get to inspecting (also should make it more pleasant for the eventual specialist...) The fuel gauge (currently in the threshold of being inaccurate) seems to fall as a result of touching the throttle.. Bizarre behaviour. My MAF arrived and always surprises just how much of a difference it makes (of course unrelated but response has been great again). |
