- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Home > Td5 > Td5 2003 - starting/turning over issue! |
roche1800
Td5 2003 - starting/turning over issue! | |
Pleas can someone advise on the likely problem, which is, when starting it seems to take a lot of turning over to start. It seems to be on ccaisions.
The vehicle is stored under cover and not exposed to the cold and also happens when you have driven it parked up for few minutes.
Many thanks in advance.
16th Dec 2023 5:09am |
roche1800
Oil change every 12 months and not many miles per annum, 5k/7k ish
16th Dec 2023 8:50am |
