Home > Puma (Tdci) > TDCi Reverse Light Switch |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2431 |
Here https://www.defender2.net/forum/post933815.html Puma 110" SW
12th Dec 2023 12:33pm |
dan.mwilliams Member Since: 11 Dec 2022 Location: South Wales Posts: 3 |
I changed mine not so long ago. I found the easiest way to do it was from the access panel under the centre cubby on the seat box. I didn't tighten it up enough the first time I replaced it so it was a little intermittent. Gave it another tighten and it's been faultless since.
12th Dec 2023 1:42pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6611 |
Search is amazing 1988 90 Td5 NAS soft top
2015 D90 XS SW |
12th Dec 2023 1:52pm |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 840 |
Check it’s not the bulb holder itself first. Start with the easiest. 2008 2.4 110 Utility Station Wagon XS.
12th Dec 2023 3:24pm |
Cam-Tech-Craig Member Since: 27 Nov 2022 Location: Cam Posts: 19 |
Thanks all?!? I’ll order one up and report back with my findings.
12th Dec 2023 6:38pm |
