Home > Maintenance & Modifications > Wing Top Chequer - Foam Gasket?
Wing Top Chequer Foam Gasket?
Yes
57%
 57%  [4]
No
42%
 42%  [3]
Total Votes: 7
ForbesOverland
United Kingdom 2012 Defender 130 Puma 2.2 HCPU Indus Silver
Morning All,
I am planning on installing some wing top chequer plates to my car with rivnuts to cover up the dented panels and give the added protection.
Question though, I have seen that there are foam gaskets available from the usual places - are they needed?
I was planning on claying and then protecting the dented wing tops with a ceramic coating and being secured with rivnuts, I will then be able to remove them if needed.
Wanted to get peoples thoughts on the foam gaskets, those for and those against....
Thank you in advance for any advice!
Forbes
Post #1017585 6th Dec 2023 7:53am
ForbesOverland
Actually, I might have asked a totally pointless question here.
I guess that because I am using Rivnuts to install the plates that I can decide if I want the foam gaskets at a later date because I can easily remove the plates!
Doh. I should not be allowed near the internet before I have fully woken up.
Post #1017587 6th Dec 2023 8:34am
paul 123
United Kingdom 1995 Defender 90 300 Tdi PU Caledonian Blue
i just pop rivited mine on
Post #1017591 6th Dec 2023 8:49am
geobloke
As above. Thumbs Up
Post #1017600 6th Dec 2023 10:09am
markb110
Without a foam gasket crud still gets underneath the wing top protectors.
You can buy a sheets of adhesive back neoprene from eBay/ Amazon and then stick in to the underside of the protector then cut to fit with a fresh Stanley blade.
Post #1017629 6th Dec 2023 2:44pm
geobloke
I suppose some thin draft excluder around the edge of the underneath of the wing top might be a good idea to prevent the crud.
Post #1017631 6th Dec 2023 2:53pm
markb110
Post #1017655 6th Dec 2023 7:25pm
Dinnu
I would not put a foam gasket under the whole panel, as due to the large surface area you would need a lot of force to compress, and most likely you would just pull the aluminum around the rivnuts upwards. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1017658 6th Dec 2023 8:16pm
db950
United Kingdom 1997 Defender 110 300 Tdi HT Nato Green
I’ve got full gaskets under mine made by Mammouth, they fit well aren’t too expensive.
These ones… https://maltings4x4store.co.uk/tf-mammouth...a-my-pair/ 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
2014 Discovery 4 SE Tech
Instagram @the110camper
Post #1017664 6th Dec 2023 8:33pm
ForbesOverland
Thanks for all your replies!
With them being a bit stoved in, I'm not quite sure what to do. I've ordered up a set of the foam gaskets, so I am just going to try and pull some of the dents out and to at least make the panel a little straighter and then rivnut the plates on and leave it a few days, remove and see what they're like underneath, then make a call on them.
I guess there is no harm in putting them on is there.
Post #1017688 7th Dec 2023 10:39am
TexasRover
Since you place aluminium on aluminium you should have little galvanic effect. Unless you see a lot of road salt or other agressive fluids I don't think you will see any excessive corrosion between the the two plates.
I would not put anything in between
Post #1017695 7th Dec 2023 11:48am
L110CDL
My wing top checker plates are pop riveted on and nothing between them Thumbs Up
I'm not a fan of rivnuts at all Censored 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #1017750 7th Dec 2023 9:20pm
