Home > Td5 > Drivers door window - dropped down
roche1800
Morning, can you help me?
When I slammed the drivers door shut the electric window fell down. I presume it has been dislodged from its runners.
Is it an easy fix?
Post #1017352 4th Dec 2023 9:08am
Chriswb84
United Kingdom 1999 Defender 110 Td5 SW Coniston Green
If you take the door card off, which is easy enough just watch the plastic clips they tend to snap and break easily and hopefully its just loose bolts holding the glass on.
Have a look at the videos below, they help explain removing the door card and what to expect, as yours is electric its essentially the wind handle is replaced with an electric motor and maybe some of the linkaging gears but I doubt you will need to touch that.
&t=651s
and
Thanks
Post #1017357 4th Dec 2023 9:51am
