Home > Maintenance & Modifications > Daughter and her 90, a lighting issue |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4722 |
My daughter has a 300 tdi 90. She phoned to say that the dip lights had gone but all others were working. Naturally enough I diagnosed the main on/off light switch. So she removed the steering cowl to check which switch she needed as there are two different connectors depending on year. She bought the correct switch and fitted it...no joy, problem persisted. So she got her mechanic to look at it. Turned out to be a burnt out wire which he fixed for her. He charged £40 which is a fair enough price. Must get a relay fitted to the light system.
The object of this post being that she changed the switch herself. She is pretty hands on Land Rover wise 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
18th Nov 2023 12:19pm |
Well done that girl
Had a similar incident on Miffy the other week. Turned out to be the relay housing of the headlight stand-alone loom made by Red Bison. The one folks put in to protect the light switch. Same symptoms as your daughters. Well it did protect the switch I have removed the loom for repair for now, but the original loom is working just fine until then. |
18th Nov 2023 5:56pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17492 |
Excellent result, but if the dip beams are working and the main beams are not it is more likely to be the dip/main/indicator switch which has melted rather than the main off/side/head switch. Generally the latter will result in no headlights at all. |
18th Nov 2023 7:52pm |
