Home > In Car Electronics > Headlamp Level Switch Illumination Fixed-ish
Ambo_Chris
United Kingdom 2013 Defender 110 Puma 2.2 USW Baltic Blue
Like most puma owners with the headlamp level switch, the bulb had blown, so I set about replacing it. Helpfully the pins on the switch are large enough to cut off the old bulb and solder on a new one. i tried an LED with an inline resistor as the feed is 12v, its a bit bright so I'll order some film to diffuse the light a bit.
The LED was 3mm prewired from eBay, https://www.ebay.co.uk/itm/262762466125?mk...media=COPY
 2013 Baltic Blue 110 Utility Station Wagon XS 2.2
2000 Beige Discovery 2 Td5 GS (Long gone)
1994 Red (various) 90 300tdi CSW (Long gone)
Post #1015422 17th Nov 2023 12:09pm
Martin
Site Admin
Good fix. Add another resistor inline to drop the current to the LED, it'll dim down then. You might need to play with the value to get it right.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1015423 17th Nov 2023 12:10pm
