![]() | Home > Td5 > Replacement fuel pipe help |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 804 ![]() ![]() ![]() |
I'll have a look.....
I did the same a few years back removing the tank in cold weather. You can just cut the outer rubber sleeve off the pipe with a knife, warm up the pipe with a hot air gun and fit the new pipe end fitting.
Steve 02' 110 TD5 Double Cab Rebuild Thread |
Something like this https://www.amazon.co.uk/Motorcycle-Couple...2c9579dee6
Or the Naka metal ones https://www.4x4overlander.com/product/naka...nes-set-2/ ![]() |
I've checked my pile of spares and unfortunately I dont have this pipe....
2hel Member Since: 28 Nov 2022 Location: Essex Posts: 177 ![]() ![]() ![]() |
Thanks everyone I think the pipe is too short now typically as I trimmed it back to try and fit the new connector.. so a replacement needed if anyone knows the part number that would be a massive help. I've seen other TD5 ones but the fuel filter side looks different
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1454 ![]() ![]() ![]() |
LR Worshop is a fantastic resource for part numbers
![]() https://www.lrworkshop.com/diagrams/land-r...es_53492#2 Possibly WJP107900 from the page above. |
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 910 ![]() ![]() ![]() |
Pioneer 4x4 now make Td5 fuel lines. May be worth contacting them. Charlie
1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
Thank you all managed to get one and get it fitted over the weekend. All sorted
