Home > Technical > Side Windows (again) |
Evil Elsie Member Since: 25 Feb 2023 Location: Cumbria Posts: 204 |
Greetings..🖖
A couple of weeks ago I drilled out the securing rivets and removed my side windows due to rain ingress. I'm really glad that I did..... Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Yuk..!! Cleaned the frames and sides up then refitted with copious amounts of Sikaflex and new rivets. Now, feeling as smug as ......... a very smug thing I awaited the inevitable rain. me..!! It's still getting in...!! It's not leaking in through the frame to side join so I've sorted that but rain seems to be getting in around the front edge of the glass and running down inside and dripping off the window runner. Hard to explain so I'll try to photo it.... I'm wondering if I have a seal missing..?? Anybody else ever had water dripping in and cured it (my initial thought was just to mastic the whole bloody lot shut/sealed)..?? Cheers, Dave 2002 Land Rover 110 Td5 Utility 1990 Suzuki GSXR 1100L 1980 Yamaha RD 350LC 1976 Yamaha RD 400C |
12th Nov 2023 1:12pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3469 |
I believe that the early frames have a joint somewhere (recall some screws as well), and possible that that joint is leaking. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
12th Nov 2023 1:38pm |
Cheers both... 👍👍
Just taken some photos which show where the drips are (same on both near and off sides); Click image to enlarge Click image to enlarge The rain seems to be making its way around the front edge of the glass and tracking down the inside, around the bottom corner then hitting the runner and dripping off... There is a joint in the frame with two screws securing the halves of the frame together but these frames are never being separated from the sides again - not without wrecking the sides anyway.... 2002 Land Rover 110 Td5 Utility 1990 Suzuki GSXR 1100L 1980 Yamaha RD 350LC 1976 Yamaha RD 400C |
12th Nov 2023 3:30pm |
