![]() | Home > Wheels & Tyres > wheel spacer safety issue? |
*Sigh* there's always one clever sod ![]() But shout it at them in German because life is also terrifying and confusing... |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17682 ![]() ![]() ![]() |
Unless you do stupid things on full lock I doubt that there'll be any problems. Most folk, if on full lock, are neither going fast nor loading the transmission much - manoeuvering round a car park for example. The loading and stress on the CV will be much greater when you're struggling for traction with the wheels spinning, then subbedly biting etc. I would also expect that the absolute limit of travel on the swivels, i.e., the point where the swivel housing seal hits the mounting flange on the inner part, will occur before the angle where the CVs start to fail. In short, drive sensibly and all will be OK. Anyway it's only an issue if you put standard tyres on spacers; if you have larger tyres chancs are the steering lock is the same as for standard tyres without spacers. |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 ![]() ![]() ![]() |
Yep, good post blackwolf, well written
![]() However not quite 100%
Spacers are not banned in all forms of MSA / FIA sanctioned motosport, Certainly if the car has been homologated with them , they are OK to use, even thin (2-20mm) ones California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2057 ![]() ![]() |
I had 235 tyres, Zu wheels. and spacers and had no problems.
Martin H. Lee Member Since: 21 Oct 2011 Location: Surrey Posts: 15 ![]() ![]() |
Hi DAZ, can I ask you something? you are using Zu wheels and spacers with 238 tyres at the same time, then how much the tyres jut out from the wheel arch? Thanks Live, Love, Pray |
Hello,
Thread was about flush with wheel arch, and side of tyre stuck out approx 25-30mm. This is the best photo I could find: ![]() Click image to enlarge I've got to ask, are you looking for Zu wheels 235 tyres?.... because I have some for sale in the 'For Sale' section if your interested. |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3481 ![]() ![]() ![]() |
Is your profile picture one with the spacers fitted? 1951 80" S1 2.0
1995 110 300TDI 1995 90 300TDI |
I meant your profile.... 1951 80" S1 2.0 1995 110 300TDI 1995 90 300TDI |
You would think if the major accessory players are selling them, there isn't an issue? 1951 80" S1 2.0
