Home > Td5 > Help on estimate for work
mustafasoleiman
United Kingdom 2003 Defender 90 Td5 XS CSW Indus Silver
Hello everybody,
My Defender needs some TLC and I brought it for an estimate of the work and this is it...
Any thoughts would be very much appreciated, the garage I never used but it came with a good reference and it specialises in Land Rovers:
Many thanks
Alex
 http://instagram.com/h4vou/
Post #1014708 10th Nov 2023 3:14pm
X4SKP
Hello mustafasoleiman
It's a fair amount of work, and what appears to be reasonable timings against the bigger aspects.
For an Independent at £100 / Hr they are possibly towards the upper end of the scale, but if good and in or close to London, then probably they're on the money. Land Rover typically will be between £120 - £180 / Hr for Defender work.
So overall at 25% Parts / 75% Labour, again this looks to be fairly typical.
As it's 'serious money' maybe get a like for like quote... Question
Good Luck SKIP
Post #1014727 10th Nov 2023 5:23pm
Screbble
I agree I’d get a second and possibly third quote using the list above.
Also agree that the hourly rate is at the upper end - but if the quality and service is excellent…
Overall the costs tally up based on what you’d expect but not sure why the rate varies for the paint work - I’d have expected the rate to remain but the hours increase?
Post #1014734 10th Nov 2023 5:41pm
Birdy
France 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
I'm one who doesn't/can no longer carry out my own maintenance, I use a cheap'n'cheerful Indie for servicing etc. when I'm in the UK, for emergencies over here I'm forced to use the main dealer in Toulon (who, funnily enough, DOES have time for an old truck, and not just brand new blinged-up JLRs).
But those prices are more French main dealer than UK Indie! As suggested, get other quotes...
Peter
Post #1014741 10th Nov 2023 6:51pm
mustafasoleiman
Many thanks for the advice and I will try to get another quotation.
Best
Alex http://instagram.com/h4vou/
Post #1014767 10th Nov 2023 9:13pm
AMBxx
I also had problems with windscreen frame corrosion. The garage advised me that they could just prepare and repaint but the rust would just return and it would need redoing in another 3-4 years.
As this was the 3rd time in 8 years (!) that it had needed to be done, I went for a new frame and had it properly prepared.
Just something to consider. I'd be interested in others' opinions too.
Post #1014776 11th Nov 2023 6:45am
