Home > Maintenance & Modifications > Gwyn Lewis 4x4 Mud shields
Cubflyer
United Kingdom 1994 Defender 90 300 Tdi SW Arles Blue
Hi folk
Decided to give the back of my chassis / rear frame a treat with the above product.
I've always had "Something" to protect the road water / mud getting to the rear frame and protect the rear light cabling but I have to say fitting the above was a joy and feeling of satisfaction.
They come as a pair and each pair have two pieces of hardish well shaped plastic complete with all clips, washers and screws.
here's a couple of pics ...
I guess they'll not be for everyone but they may well suit someone (Price around £45.00) 2010 Defender 90 300Tdi CW (White/1994)
2021 Defender 90 300Tdi SW (Blue/1994)
Post #1014605 9th Nov 2023 10:06pm
Screbble
They are really good - as are all thinks GL 👍
You’ve done a grand job there.
I was only able to fit the upper part due to the rear seat belt reinforcing bars interfering with the lower part ☹️
Post #1014606 9th Nov 2023 10:11pm
geobloke
Yup these are on my Christmas list Thumbs Up
Love GL gear. Seriously practical with a heap of R&D gone in to the products.
Post #1014608 9th Nov 2023 10:15pm
HardCharger
I bought almost all of the under body shields and am waiting for DHL to drop them off today.
I didn't get the ones for the front bumper as I have a custom front bumper on my truck.
I got the hints my truck was giving me when I suddenly lost the front right mudflap and found the rear right one hanging by the bracket bolted to chases alone! Almost lost it! Shocked
Will find the time to install hopefully before the holidays roll around. Thumbs Up
Post #1014646 10th Nov 2023 6:07am
kenzle8a
I had them on my old truck, they definitely did their job especially on the front outriggers.
My only complaint is the speed screw fixings, horrible things and I did notice one had fallen out at some point on my one. Not the best thing to have fallen onto a road Shocked
I swapped the fittings out for marine bass / rubber rivnuts and normal A4 grade bolts covered in antiseize with A4 grade washers as it was a much more secure fitting and you didn't have a speed screw going into metal / with a chance to fall out.
The 2 part ones with the P-Clips (again awful things) I did the same and enlarged the holes and used the brass / rubber rivnuts.
Post #1014652 10th Nov 2023 7:48am
Bluericky
United Kingdom 2009 Defender 110 Puma 2.4 DCPU Keswick Green
Great bits of kit and a fairly obvious upgrade if you have a chassis in good nick .
I opted for the stainless mudflap brackets with quick release fittings (for the rear), I replaced some the brackets maybe four years ago with powder coated jobs and they lasted all of two years before corrosion took hold.
My only tip if fitting the GL rear mudflap brackets, is don't follow the instructions to the letter. I cut my mudflaps as instructed and realised that after fitting them there was absolutely no need and in fact now look a bit short an stubby . I should have left the length as they were .
I suppose there's good reason for it as they're up out of the way, I have ripped one off a previous defender whilst reversing up a bank , that's not going to happen now !
I should note that this mod is on my 130 not 110 https://www.instagram.com/hustynminepark/
Post #1014657 10th Nov 2023 10:08am
Retroanaconda
They are very good and work well. An alternative if you’re tight like me is to make your own out of 3mm HDPE sheet. You can then make them longer too.
Post #1014807 11th Nov 2023 3:14pm
TexasRover
Yes really good. At the front they work well with their mudflap repositioning brackets. For the 110 the rear rear bracket I think could have been moved forward to align with the mudflap bracket so the whole rear end becomes a large cavity protected from mud which would then include things like exhaust hangers etc
Post #1014810 11th Nov 2023 3:51pm
TexasRover
Just had s look at it seems they have developed a better rear protection with part nr GL1008, so ignore earlier comment
Post #1014811 11th Nov 2023 3:56pm
Cubflyer
Continuing on ... I began to fit the front one's (GL1010) this afternoon. Just the driver's side alone took over four hours to fit! Mad
Basically the metal wheel arch was out of alignment with the bulkhead securing brackets so it took prybars and adjustments (various) to get it fitted.
Now fitted ... I must say I'm very please with the protection it offers to the forward outriggers Thumbs Up
Now done, start the other side tomorrow ... Very Happy 2010 Defender 90 300Tdi CW (White/1994)
Post #1014819 11th Nov 2023 6:48pm
Screbble
Good job well done 👍
Post #1014823 11th Nov 2023 6:57pm
WilkoW
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Atlantis Blue
Gwynn Lewis do some excellent products and having fitted these to mine I can vouch for them. It’s the little things they think about I like, for example, on my OME dampers he supplies, they come with shrink wrap plastic to cover the damper housing to prevent / delay the inevitable stone chips. I’m looking forward to fitting the wading kit next…
Post #1014827 11th Nov 2023 8:54pm
Screbble
I think it is more than fair to say, and the vast majority on here would agree, that Gwyn’s products are excellent - really high quality and well thought through.
I’m like a child in a sweet shop when looking at his website 👍
Post #1014848 12th Nov 2023 9:34am
Mossberg
United Kingdom 1993 Defender 90 300 Tdi HT Aintree Green
What size sheet did you get for that. I did actually consider making similar from galv sheet, but I think that hdpe will be easier to cut and handle, and obviously even less prone to corrosion.
Post #1014855 12th Nov 2023 11:05am
Retroanaconda
An 2m x 1m sheet was about £80 if I remember correctly. Enough material to do shields for the rear of the front arches and both front/rear of the rear arches.
Post #1014858 12th Nov 2023 12:20pm
