Home > Puma (Tdci) > power loss!! |
ZeDefender Member Since: 15 Sep 2011 Location: Munich Posts: 4731 |
Many thanks - love to learn Incidentally, it also appears to break wires Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
3rd Nov 2011 10:49pm |
CRJ Member Since: 12 Mar 2011 Location: Sealand - Denmark Posts: 253 |
Found the leak......between the manifold and turbo - one nut missing the two others a bit loose... It seems to me that the gasket ( nakatanega) is a bit hard - shouldn't it be compressed a little bit when one tighten the nuts?
Regards CRJ 88 Ser. 3 1980 -sold Puma 130 - 08- sold 90 200tdi 1991 - sold 88 Ser. 3 1977 200 TDI 110 CC 2003 |
5th Nov 2011 11:41am |
The reason I asked earlier as to who fitted the annealed copper gasket was to ascertain whether or not they replaced the manifold studs as well. Once these gaskets have been substituted for the OEM ones I personally would replace the studs and nuts and keep trying to tighten them over a period of a week or so to take into account any heat stretch when new studs/nuts are used. Remember it gets very hot in there and metal expands when hot.
Brian. |
5th Nov 2011 3:27pm |
