Home > Maintenance & Modifications > R380 Copper washer
Yorkshire90
R380 Copper washer
Does anyone know where I can pick up a copper washer for the r380 gearbox drainage plug that doesn't cost £4?! It's a copper washer for crying out loud. Rolling Eyes
I've seen a magnetised plug and washer for a tenner on eBay. Yet a single washer nearly costs as much with postage..
Can't remember if mine is magnetised or not when I changed the oil last.
Thanks in advance Bow down "Big green" 2000 Td5 90 IRB Developments modified (2004-2011)
Discovery 3 TDv6 GS Auto 2011-2012 *Missed the Defender too much*
IRB Developments rebuild: Project Ice cube 2012-......
http://www.defender2.net/forum/topic11056.html
Post #1013133 29th Oct 2023 8:12pm
markb110
Funnily i thought the same a couple of weeks ago, i ordered the plug and washer from ebay just to be on the safe side as i couldn't remember if it was magnetised. It was.
For the sake of the cost of the washer and postage i thought what the hell, get both so not to delay the job.
Post #1013143 29th Oct 2023 9:54pm
Screbble
Alas I recall I paid about £4 including postage for two last time I bought some (eBay). Still relatively expensive at £2 ish each but I couldn’t find an alternative at the time.
Post #1013144 29th Oct 2023 9:55pm
Yorkshire90
I was wondering if it was a fairly generic size. Just received a filter kit for the td5 and it comes with a copper sump washer. Typical as I already have a Femco quick drain connection fitted.
Might be cheaper to pop in my local main dealer. By the time £5 postage as been added I wouldn't be surprised. "Big green" 2000 Td5 90 IRB Developments modified (2004-2011)
Post #1013147 29th Oct 2023 10:10pm
Martin
Site Admin
FTC4112 is 55-75p for aftermarket, £4 genuine.
So £4 on eBay is presumably to cover postage, handling, fees etc on a 75p item.
On LR Workshop someone's listed the dimensions (the 1.5mm is the thickness).
https://www.lrworkshop.com/parts/FTC4112  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1013153 29th Oct 2023 11:18pm
Mossberg
United Kingdom 1993 Defender 90 300 Tdi HT Aintree Green
Might be worth a call to a local motor factor's, but unless they are near you the £4 from ebay will probably not be that much different than the cost of fuel and hassle.
I tend to order things like this in a bag of 10 when ordering so I don't have to pay postage on a pennies part - this ends up being really useful when I come to need them and can't find them 🙃!!
Post #1013156 30th Oct 2023 5:30am
Yorkshire90
Thanks all. I've got a decent auto shop near me, ASK in Kippax.
Tbh, if I can't find a match at the shop, I'll probably just buy a couple from eBay as I used Gen 'part' MTF94 last time but bought Granville MTF94 (what ASK had in).
Some folks have said they wouldn't give Granville MTF94 to an enemy but that sounds like an exaggeration! Castrol syntrans for the Tbox though. Might just leave it in there for a year. "Big green" 2000 Td5 90 IRB Developments modified (2004-2011)
Post #1013160 30th Oct 2023 8:09am
Yorkshire90
Just bought 3 from here..noticed they did free postage..discount for buying more than 1.
Bearmach
https://www.ebay.co.uk/itm/222092614308?mk...media=COPY "Big green" 2000 Td5 90 IRB Developments modified (2004-2011)
Post #1013190 30th Oct 2023 12:00pm
Yorkshire90
Already dispatched and on the way..great service. "Big green" 2000 Td5 90 IRB Developments modified (2004-2011)
Post #1013216 30th Oct 2023 3:34pm
Screbble
Bargain 👍
Post #1013242 30th Oct 2023 6:24pm
NickMc
Granville is awful cheap rubbish I wouldn't use or sell it. I use ATF dextron III instead Thumbs Up
Some of the cheaper aftermarket washers aren’t actually “copper” beware. If you’re really stuck you can anneal the one you have with a blow torch and re-use.
Post #1013252 30th Oct 2023 7:05pm
Yorkshire90
I'll check. They were around £3 and labelled as Bearmach. The seller has tens of thousands of sales in 4x4 parts. Will check them out when they rock up.
Are there anecdotal reasons for Granville MTF94 being crap? They give it the big one on the website. I don't recall it being that cheap either Neutral
"Granville MTF 94 Manual Transmission Fluid is formulated
using high quality base oils and the very latest additives to
produce a fluid that is designed for use in specific high load
manual transmissions to prevent premature synchronizer
wear, poor gear shifting and ultimately transmission failure.
Recommended for use by Granville for the
following manufacturer's specifications
API: GL-4
Product Benefits
* High load protection
* Excellent shear strength and stability
* Long life lubricant" "Big green" 2000 Td5 90 IRB Developments modified (2004-2011)
Post #1013289 30th Oct 2023 11:07pm
