Home > Wheels & Tyres (L663) > BFG Ko2 All Terrain Tyre Pressure 275/55/20
Hillbilly
Hi, just wondered if anyone has the correct tyre pressure for 275/55/20 to use on a 110 please
Both light and heavy pressures if known would be great.
Thanks in advance
Post #1011977 21st Oct 2023 8:50am
Mikemillar89
Hi do you get any rubbing with this tire size?
Thanks Mike
Post #1016862 30th Nov 2023 6:39pm
Hillbilly
No, not that I’ve noticed. They are fitted to standard style 5095 wheels. Ride is a little firm and slightly noisy, but we are used to them now. Certainly not as noisy as some people report.
Post #1016874 30th Nov 2023 6:56pm
Cheshire110
Does your car not have the TMPS? You can switch between heavy and light load on the driver's instrument panel and it also shows you the recommended pressures.
Tyre choice / size won't meaningfully impact the pressures you need Cheers, David
Post #1020524 8th Jan 2024 2:10pm
