Home > Puma (Tdci) > Puma Suspension
lakes
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Puma Suspension
I had my Defender in the garage earlier this week for a service, mechanic gave me a ring to say the two rear shocks were completely busted, one was hanging off. Gave them the go ahead to replace them with stock LR ones.
I cannot believe the difference it’s made - it’s like a new car.
My question is do I get the front ones replaced too? They are originals so are knocking on 13 years old.
Mechanic said they were fine.
Post #1011744 19th Oct 2023 7:32am
MartinK
Rears made the biggest difference on my 110, doing the fronts had less impact/benefit but mine was quite new at the time
I put Koni Heavy Track on mine, it seemed a good upgrade - thread here https://www.defender2.net/forum/topic16066.html Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #1011748 19th Oct 2023 7:48am
MK
Re: Puma Suspension
Did the mechanic remove the front ones to "test" them? Puma 110" SW
Post #1011765 19th Oct 2023 9:45am
lakes
No - I think him saying they were fine meant they weren’t bust open like the rear Mr. Green
Post #1011768 19th Oct 2023 10:17am
MK
Depending on the usage or miles sometimes it is necessary to remove a shock absorber to test them. If it does not leak does not mean it is good. Sometimes they loose their gas charge and internals wear. Puma 110" SW
Post #1011769 19th Oct 2023 10:33am
FWIW my 2007 270k mile Defender is still on the original front dampers.but not rears.
Post #1011777 19th Oct 2023 11:39am
Chicken Drumstick
What I find amazing here is. How can any sensible owner not know they have shocks hanging off!!!! Do such owners have their eyes closed shut whenever they walk near to their own vehicle???? Quite worrying that such owners and vehicles are allowed on the roads really.
Post #1011795 19th Oct 2023 2:23pm
lakes
I’m not a mechanic, hence why I asked advice on a forum - and it’s in the garage every 6 months for inspection/service.
Post #1011798 19th Oct 2023 2:31pm
Mdm
i would swap them as long as you dont use britpart oes itll be good for 10+yrs again
Post #1011800 19th Oct 2023 2:34pm
Chicken Drumstick
Re: Puma Suspension
If the front are fine, then changing them will make little difference. Do you know many history on the vehicle or how many miles it has done?
Is it modded for off roading?
Shocks are pretty cheap in terms of car maintenance and you can fit them yourself if you want. So it might not be a bad thing to do. But it depends on what you plan to use the vehicle for on what would be a good replacement.
For a budget shock, I quite like the Britpart Cellular Dynamic range. You can get them in stock length or +2". If changing the fronts you'll need some new turret rings are a must. Any brand HD glav ones should be fine. I'd also look at new turrets too. The Gwyn Lewis standard height ones are a good price and an open design. So makes fitting (or removing in the future) easy and they won't trap mud and dirt like the standard design.
Post #1011836 19th Oct 2023 4:51pm
Martin
Site Admin
Not an acceptable response to anyone on this forum. Do not speak to others like this again.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1011841 19th Oct 2023 5:11pm
Naks
I would replace the fronts as well, but that's me: I like to know that components that work in unison are all of the same age/wear & tear. --
Post #1011876 20th Oct 2023 5:59am
rustandoil
I would get the fronts renewed.... Fresh dampers front and rear can't be a bad thing....
If you're happy with standard spec' that will save you a few quid 👍🏻
Post #1011879 20th Oct 2023 6:55am
Matt_H
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Zambezi Silver
The thing is dampers are so cheap that its worth treating them as a service Item IMO (not every year). The rubber bushes all wear with use too, so for the sake of £40 a side every few years, you might as well replace them and have a better drive. Its funny the number of people who swear their dampers are absolutely fine, but then comment on the improvement having fitted new ones !
Post #1011897 20th Oct 2023 11:07am
