Home > Maintenance & Modifications > What's the highest sidewall on an 18" rim?
Grenadier
Bonjour,
What's the highest (sensibly highest) sidewall that I can put on an 18" rim on an unmodified 110 with standard ride height? I'm looking to fill the gap between wheel and arch just a little more. And I've also got slightly hooked on the larger tyre look (but not to the degree os some silly US style monster truck. Indeed, not even the tyres on a Spectre.
Any answer shouldn't adversely affect ride-height, handling, speed indicated on speedo, fouling under the wheel arch whether on or off-road etc.
I'm currently running 65s, was wondering at 70s, 75s?
Any thoughts? Thumbs Up Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #1011739 19th Oct 2023 7:05am
Chicken Drumstick
Not 100% convinced on 18" rims on a Defender, they always look, well a little odd.
Also on a 4x4, you normally don't want to fill the arch. You want clearance, even more so if you plan to off road.
Stock tyres are 31-32" tall. Generally 33's are fine and if you drive gentle plenty have run 35's, else you really need to be modding axles and diffs. Max for the axles is probably 37" tall. But you'll want supporting mods most likely for anything over 33".
Wide tyres generally perform worse off road over narrow ones and also allow more steering lock. With less chance of rubbing or sticking out of the arches.
Best bet is just to look at what 18" tyres are on offer and their diameter and go from there.
Post #1011782 19th Oct 2023 12:16pm
LJMARSDEN
United Kingdom 2006 Defender 90 Other HT Java Black
There are calculators online for tyre diameter and circumference if needed.
People suggest 33" is enough. 4.0 V8 Defender 90
My Instagram
Post #1011802 19th Oct 2023 2:37pm
Ianh
As others have said use a tyre size calculator site .i.e https://tiresize.com/comparison/
And put in the specific wheel and tyre details. you can also put in offsets to see how that impacts stops , rubbing on arches etc.
Note the 60, 70, 75 etc number is a percentage of the width or the tyre not a measurement in itself, I.e a 265/75 will be a greater diameter than a 255/75.
Post #1011807 19th Oct 2023 3:00pm
jimbo55
I run 275/70R18 toyo muds on my 90, if you want a mud terrain it’s about the only sensible option that isn’t a 33x12.50r18
Bfg do all terrains in 285/65r18 and I think there are others that do 33” but not overly fat tyres for 18” rims
Either way a 33”diameter tyre on 18” rim will give you pretty much the same sidewall height as a stock 235/85R16
On road handling is considerably better than the 255/85r16 bfg muds I had previously, especially in the wet
I find my td5 speedo runs pretty bang on with a 33” tyre
If I off-road standard height (it’s on air so can choose) then it can just about catch the corner of the rear wheel arch, (9Jx et0 twisted rims) when I max out the suspension flex but it is pretty rare -if I’m on a pay and play I might hear it once or twice in a day at most.
Would definitely recommend them 👍
Post #1011821 19th Oct 2023 3:58pm
Likeomg
I previously had BFG 285/65/18 however moved to the cooper's 285/60/18 and in my opinion fill a defender out properly...
No issues off-road either although I don't have a factory suspension setup.
Post #1011880 20th Oct 2023 7:31am
LJMARSDEN
Damn, I think they look spot on Jimbo. This may be what my 90 needs..
I feel I may have to change my tyre soon nnow, I'm quite jealous of the look. Big Cry
Radar renegade 275/65/18 4.0 V8 Defender 90
My Instagram
Post #1011883 20th Oct 2023 7:51am
