Home > Puma (Tdci) > Water Pump & Vacuum Pump Gaskets
driver
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
Looking for a bit of clarification from the knowledge here,
I am about to change the water pump on my 2.4 tdci and the gasket included with the Borg and Beck pump have depressions in them around a couple of holes presumably to seal better,
I am sure I have seen somewhere that there should be rubber O rings as well, am I mistaken or do I need to source these as a separate item?
If so does anyone know the part numbers? picture added for clarification.
Again thanks in anticipation.
Post #1011654 18th Oct 2023 10:14am
