![]() | Home > Technical > Clutch Pedal Removal without draining hydraulics |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1679 ![]() ![]() ![]() |
You’d have to bend the pipe a bit, but how are you going to remove and reinstall the flexi hose for the slave cylinder that attaches to the bulkhead?
akuankka Member Since: 18 Oct 2022 Location: Hampshire Posts: 2 ![]() ![]() |
Great point ! And that is exactly what I was missing !
I hadn't followed the pipe route all the way back to the slave cylinder in enough detail to see that bulkhead hoop that the pipe / flexi hose connect on. You are right, I cant see a way of getting around disconnecting that joint there, so no point faffing about more than necessary by the master cylinder. Thank you very much !!! |
I would personally swap out the master cylinder whilst you have it off for the price of it too.
Steve 02' 110 TD5 Double Cab Rebuild Thread |
I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 828 ![]() ![]() ![]() |
I personally would not change a working master cylinder just for the sake of it! There is so much
