Home > Maintenance & Modifications > Puma Wiper Arms |
gcc130 Member Since: 05 Jun 2015 Location: Wiltshire Posts: 750 |
Open the plastic cover, undo the nut, 13mm if I remember correctly, and then prise the arm off the splined shaft.
I use two open ended spammers to prise apart. |
6th Oct 2023 1:45pm |
As above. It is a 13mm flanged nut. You might require a wiper puller, they are not expensive and worth the money IMHO.
6th Oct 2023 2:02pm |
mwestcrew Member Since: 09 Dec 2019 Location: South Warwickshire Posts: 268 |
Wiper puller is one of the best value and most useful tools I have bought recently. 2011 130 Utility Body
2005 110 Van |
6th Oct 2023 8:43pm |
ChrisDefender Member Since: 29 Oct 2015 Location: Midlands Posts: 456 |
Hi all,
Many thanks, very helpful. Cheers. |
9th Oct 2023 7:46am |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3437 |
Wiper puller is a good tool to have.
But if caught in a pinch and need to remove a stuck wiper arm, I had good success using a mole grip (was successful on a very stubborn wiper arm). Just loosen the nut enough to have good clearance between the base of the nut and the wiper arm (1 to 2mm, but ensure still good thread connection). One jaw underneath the wiper arm, and one jaw on the nut. Adjust the mole grip to get good pressure and should pop off. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
9th Oct 2023 8:15am |
