- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
MD5 wrote:My 2008 rig has done 25000km. I don't feel particular clutch problems, anyway today I put my telephone on the ground just under the transfer unit to record any possible strange noise when the engine was turned off.
Here you can listen it in .mp3 format:
http://k003.kiwi6.com/hotlink/euk5a0qhhu/engine_off.mp3
Noise can be a little harsh than inside the vehicle because the recorder is very close to the transfer unit.
Do you heard something strange ?
I guess the noise you're asking about is the mechanical farty sound just before the EGR cleaning cycle? I don't recognise it but it doesn't sound like the noise my clutch used to make. Does the noise still happen if you stop the engine with the clutch pressed to the floor?
It could be caused by backlash in the Tbox allowing the gears to rattle a little.
2nd Nov 2011 10:52am |
