Home > Puma (Tdci) > Just my Luck . . . |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2420 |
Really bad!
were you using the specified coolant/changed according to recommendations? Puma 110" SW ............................................................. Earth first. Other planets later |
26th Sep 2023 1:06pm |
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 896 |
Yes, correct spec coolant.
I know the EGR cooler is a common point of failure. I expect it was a combination of high EGTs on the steep Portuguese motorways and an 11 year old EGR cooler. Charlie 1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
26th Sep 2023 1:12pm |
Ok but another major point of unreliability. Lucky you were not in the middle of Australia or Turkmenistan. Another point for the Troopy. Puma 110" SW
26th Sep 2023 1:16pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2027 |
Ian at IRB developments ( porny on here and site sponsor) has highlighted the issue with the 2.2 EGR cooler leaking
See link https://www.facebook.com/IRBdevelopments/v...591089960/ It’s the first failure I’ve read of on this forum though and seams to have quite significant consequences re head gasket. Hope all gets fixed ok and you get to recommence your holiday. |
26th Sep 2023 1:25pm |
Yes, I was lucky I was still in Europe. It wouldn’t have been fun to have this happen in the Sahara . . . Charlie 1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
26th Sep 2023 1:28pm |
I’ve been messaging Chris at Venture 4x4, as my regular go-to when in the UK, and he suggested the EGR cooler straight away. Looking online, it seems quite a well known weakness of the TDCi engine in all applications (LR/Ford). It certainly adds weight to the argument for deactivating the EGR and bypassing the cooler. Thanks! Hopefully I’ll be wheels rolling tomorrow or the day after. Charlie 1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
26th Sep 2023 1:32pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3419 |
As I understand, for a 2.2 you need to get a DPF and EGR delete at the same time. You cannot do an EGR delete only. But I stand to be corrected. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
26th Sep 2023 1:49pm |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 530 |
I think when I spoke to bells in York I was told that if you disable the dpf function you effectively disable the egr from it's normal working but still have to leave it electrically connected as it still does some sort of purge at shutdown.. May be getting it wrong but I remember on my mk 7 transit you could hear a sawing noise when tou shut down sometimes.. I was told that was the egr valve cycling..
26th Sep 2023 2:24pm |
Yes, that noise on shutdown is the EGR. The TDCi in Defender form does the same cycle. Charlie
26th Sep 2023 2:32pm |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1079 |
Unfortunately all these emission control system are a high point of failure on a lot of modern cars, but without it nowadays you cannot drive around a bunch of cities. Pros and cons.
Shop looks nice! I would not call it luck you found them. You knew were to look for them and you are obviously well prepared to deal with set backs. Makes for a good story later in the pub no? |
26th Sep 2023 2:42pm |
Time to bypass it on my 2.4 I guess Puma 110" SW
26th Sep 2023 3:23pm |
Makes me glad I’ve removed it on the Td5. Fortunately I have a bit of a Portuguese contact, who was a total hero yesterday. That is very true! These things are sent to test us. Charlie 1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
26th Sep 2023 3:27pm |
I would seriously consider that! Charlie 1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
26th Sep 2023 3:28pm |
Race.it Member Since: 27 Aug 2019 Location: Algeciras Posts: 823 |
Not defender related but the wife’s daily egr cooler (BMW) let go the other day limped it 200km hole with frequent coolant refills, just waiting for the replacement to arrive from Germany so it can be repaired. Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details |
26th Sep 2023 4:38pm |
