Home > Faults & Fixes (L663) > I have a few questions regarding the L663 from Ukraine. |
Nuclear Nick Member Since: 21 Aug 2021 Location: Southwest Posts: 282 |
I had your second issue, the transmission noise on full lock, on my V8 90. Dealership changed transfer box oil and did a software update in accordance with LR service bulletin. They couldn’t then replicate the noise so handed it back to me for longer term testing. The noise on full lock has gone but I do notice the occasional noise at slow straight ahead speeds when there is slight on/off power applied. So the issue is 95% fixed I guess but remains to be seen what happens over time.
24th Sep 2023 9:31pm |
AGamingPlus Member Since: 24 Sep 2023 Location: Kyiv Posts: 6 |
Today, I visited another service center. Regarding issue 1, it turns out this is how AdBlue operates. As for the second issue, they changed the oil in the transfer cases, and the problem went away. The only thing is that they don't do it under warranty here.
25th Sep 2023 4:23pm |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2763 |
Welcome to the forum! l am glad you managed to get your vehicle sorted.
I hope things are safe for you in Kyiv Ukraine with the ongoing conflict. |
26th Sep 2023 6:52am |
Hello, thank you. As for Kyiv, we've gotten used to a lot here. From sitting without power for 3-4 days during winter to missile attacks
27th Sep 2023 2:20pm |
Hard to imagine what it must be like sat in your home listening to missiles landing in your neighbourhood.
l assume you have secure parking for your Land Rover. Stay safe. Hopefully it will be over before too long. |
27th Sep 2023 9:52pm |
Yes, it's parked in a secured parking lot near the house. But due to the war, there isn't much crime right now. We've become so accustomed to the missiles that I often step out onto the balcony to watch them get intercepted. Sometimes they're close, sometimes far away. Over time, the sense of fear dulls. You start to feel indifferent - if it's your fate to die, there's no escaping it. Though the most terrifying moment was when Kyiv was targeted by 'Kinzhal' missiles. They were intercepted by the Patriot system, and many were shot down right above our house. Fragments of some missiles landed about 400 meters from us. The entire sky was red with explosions and glow.
27th Sep 2023 9:59pm |
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1370 |
Bonkers to think we are on a forum discussing this.
My thoughts are with you and those fighting for your freedom. Glory to Ukraine. 🇺🇦 Eiger Grey MY23 D250 SE with bits. Known as Noddy. |
27th Sep 2023 10:07pm |
To answer your first question l too get this clicking when l first start up the Defender. l think it's normal.
2nd Oct 2023 8:00pm |
One more question. After replacing the front air springs, the car still drops slightly overnight, about 1 cm. Before the replacement, the front would drop all the way down. I was told that this is normal for the Defender. But it shouldn't drop more than 1 cm. Also, today after changing the transmission oil, I noticed that if I raise the car to off-road mode, first putting the gearbox in neutral and engaging the parking brake, and then once the car has raised, switch to drive, there's a strong jolt to the vehicle. Sometimes it's loud, sometimes it's not. Is this normal? |
2nd Oct 2023 9:19pm |
DFNDER Member Since: 02 Oct 2023 Location: Perth WA Posts: 132 |
The jolt is the suspension releasing the last bit of tension that the park brake puts in. A good tip is to lower the car to access height as you roll into your parking bay, then apply the park brake at the very end. Same when you drive off, raise the car in neutral or in drive, with the park brake off. This removes all stress from the suspension and improves the life of your control arm bushes, shocks and EAS bags.
The EAS should not drop at all, if it does, you have a leak in the system somewhere, either at the strut, or one of the distribution blocks. Test with soapy water in a spray bottle, if you see bubbles you know where the leak is. Stay safe in Ukraine |
4th Oct 2023 8:52am |
Thank you for your response and your advice. I appreciate it!
4th Oct 2023 8:26pm |
