Home > For Sale & Wanted > [Wanted] Superwinch/winch remote socket
TamarBlue11
United Kingdom 2011 Defender 90 Puma 2.4 HT Tamar Blue
Has anyone got one of these they don't need anymore?
https://www.blackdownoffroad.co.uk/product...ol-socket/
Or even a controller and socket?
Post #1007251 11th Sep 2023 5:49pm
mick
England 2010 Defender 130 Puma 2.4 HCPU Rimini Red
Post #1007253 11th Sep 2023 5:58pm
rallysteve
I am sure i have one somewhere. I will have a dig around Thumbs Up
Post #1007256 11th Sep 2023 6:35pm
I have a surplus plug and socket originally from a Husky 8, if I can remember where I've put them.
Post #1007269 11th Sep 2023 8:08pm
TamarBlue11
Thanks guys definitely interested. Thanks for the link Mick will have that as a backup.
Post #1007273 11th Sep 2023 8:16pm
TamarBlue11, are you sorted yet?
I have found the one I remembered having, and actually found I have two, one is plastic-bodied and is exactly like the one in the link you posted, the other is metal-bodied but differs from the plastic version in that the female part of the connector in the remote and the male on the winch.
Both are sets consisting of the panel-mounted receiver and lead-mounted plug, the metal-bodied set has the whole of the remote lead (but not the remote itself). Both were removed from Fairy/Superwinch Husky winches by me, since I use an entirely different (and in all honesty better quality) connector on all my Huskys.
Let me know (PM is fine) if you are still looking, otherwise I will advertise them on the forum fisrt and then stick them on Ebay, since they are no use to me.
Post #1007818 16th Sep 2023 12:36pm
sorry to hijack this post....
BlackWolf.... what connectors do you use?
Post #1007866 16th Sep 2023 6:11pm
TamarBlue11
Thanks blackwolf, pm sent. But also interested in what you use now instead!
Post #1007879 16th Sep 2023 8:57pm
Bulgin Buccaneer waterproof connectors which I usually buy from RS Components. I was going to paste a link but the RS website is down for maintenance. Here's a link to the plug on the Bulgin site but you'll need to explore the other parts in the series. I use a cable plug, panel socket, with waterproof caps on each and a strain relief sleeve on the cable. I've used these for years, they are economical, reliable, robust, versatile, and fully waterproof. They are also available with a huge range of numbers of pins, and the male and female parts are interchangeable.
https://www.bulgin.com/en/products/flex-ca...nsert.html
Post #1007889 16th Sep 2023 11:17pm
mick
I use those on my Rib console it’s good kit
Post #1007990 17th Sep 2023 8:33pm
