![]() | Home > Modifications & Maintenance (L663) > Aftermarket Mud Flaps and Side Steps |
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1261 ![]() ![]() |
this may not be the answer you were looking for.
don't fit either. the mud flaps will pull off when mudding off road. the side steps reduce your ground clearance. Why would you want that ? |
Mrh1818 Member Since: 22 Jul 2023 Location: Aberdeen Posts: 21 ![]() ![]() |
I won’t be doing any off-roading so they are for easier access and to prevent dirt and mud splashing up the side of the vehicle…
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3453 ![]() ![]() |
The mud flaps are extremely flexible, had this LR press car off road and whilst they caught a bit they stayed on and returned to shape. ![]() Click image to enlarge 24MY 90 D250 HSE, Tasman Blue |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3016 ![]() ![]() |
I fitted aftermarket side steps at 1/5 the cost of the Land Rover ones, and they were pretty much the same.
The tubes and brackets were the same. The actual step was some sort of plastic rather than the alloy of the LR steps but it was very strong and possibly even better as it won't corrode. Top picture is aftermarket, lower picture genuine ![]() Click image to enlarge ![]() Click image to enlarge |
RickyBobby Member Since: 27 Jan 2023 Location: UK Posts: 15 ![]() ![]() |
I would say buy the original mudflaps as the classics have the logo which is highly visible from the rear.
I bought side steps from PowerfulUK as they provide all the clips too, which you will need as they will break. The quality is OK but things don’t align fully, but who says the factory ones fit perfectly too. S |
You don't need to pull off all the trim, to fit the side steps.
Just use the two long bolts on each bracket and don't bother with the two smaller ones that go into the sides of the bracket. They are absolutely fine with the larger bolts only. Not even sure why the side bolts are used. Maybe so you can use the side steps as rock sliders lol ![]() Click image to enlarge |
DAP2022 Member Since: 16 Feb 2022 Location: Norfolk Posts: 120 ![]() ![]() |
I suppose for the £1100 side steps the side bolts mean they're harder to steal, as you have to dismantle steps and take of trim to get to bolts
RDR Member Since: 27 Apr 2018 Location: Derbyshire Posts: 595 ![]() ![]() |
Side step theft is real, I had a spare wheel and sidesteps stolen when I left my Discovery 4 in Chesterfield train station carpark for a few nights. Replaced the steps with aftermarket and found some security bolts to fit. 110 MY23.5 X Dynamic HSE
RR MY23 HSE PHEV D5 MY19 HSE - Now Sold D4 MY16 HSE Luxury - Now Sold D4 MY12 HSE - Gone D3 MY06 S - Gone but not forgotten |
I went with the genuine steps, Grange Land Rover had money off them. 24MY 90 D250 HSE, Tasman Blue
Genuine and aftermarket
Top picture genuine Lower picture aftermarket Pretty much the same. Having said that l ended up with a pair of second hand OE ones as l preferred the silver trim. ![]() Click image to enlarge ![]() Click image to enlarge |
This what 'after market' side steps could look like in a very short time.
![]() Click image to enlarge Go Genuine. |
These aftermarket ones had plastic steps so unlikely to corrode.
...... and they lived by the north sea coast, 'kipper country'
