Home > General & Technical (L663) > Clear view mirror |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1426 |
There are 2 versions of the Clearview mirror available with and without the homelink buttons, if you are buying a new car I would think it would be cheaper for you to spec it on your build. If you are retrofitting it you can enable it with the GAP tool, have a look at Marco's thread
https://www.defender2.net/forum/topic88338.html Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
10th Sep 2023 5:22pm |
Tomboy07 Member Since: 10 Sep 2023 Location: Donegal Posts: 4 |
Thankyou. Car comes with clearview. I will order homelike as well.
10th Sep 2023 5:23pm |
Yes I think adding Homelink to your build is only about an extra £200 whereas the Homelink mirror is around £900 to buy as an afterthought Cheers Ian
10th Sep 2023 5:34pm |
