![]() | Home > Technical > Defender 90 High water temperature. |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6642 ![]() ![]() ![]() |
Ha I knew it
![]() ![]() I haven't been able to source the rubber bullet socket, but I do have some compatible alternatives with a clear boot. If the terminal inside is OK you could carefully cut the perished rubber away and replace with a few layers of heatshrink for protection/reinforcement. ![]() ![]() |
