![]() | Home > Td5 > Welding |
Defendertomten Member Since: 19 Aug 2020 Location: Avesta Posts: 48 ![]() ![]() ![]() |
How unsafe is it to weld on chassis parts with battery connected? Anyone who have welded and burned something?
I really dont want to activate my immobililizer because its not fun nor easy to get rid of it with the eka code and a loose cable to the doorswitch Land Rover owner since 2003 2008 Disco3 manual 2000 Defender 130 td5 snorkel warn m6000 |
Inadvisable is the answer I am afraid. Also just be aware that the loom is in the right hand (facing the rear door) chassis rail.
Do you not have a key fob then? |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2320 ![]() ![]() ![]() |
All the guidance and manuals will tell you to disconnect the battery...
I have welded loads of vehicles with battery connected without issue > 110 XS Double Cab |
MarkBrown Member Since: 03 Oct 2022 Location: Mid Wales Posts: 529 ![]() ![]() ![]() |
I've done it several times before on my own stuff with no problems. I guess that problems can occur if the earth is bad and the current then tries to earth through the battery or ecu etc. I've just made sure that the earth point is clean and close and the pieces your welding are clean. But it's not my car either....
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1200 ![]() ![]() ![]() |
My work is with ships (seagoing type) just finished a big project in a shipyard with a lot of welding. Obviously proper grounding (if you don't it eats your steel where it grounds out on seawater). All good till we tried to fire up a few generators, no luck synchronizating them, all the controlboards needed replacing. Stray welding currents appearantly fried them. Not cheap, next time we will just remove all the boards beforehand
Yes i have the key fobs. But i think its some failure in them. I have read several times before about the system but now i have forgotten. Isnt there a coil in the key wich is inducted via the plastic surrounding on the ignition key lock? But if i change my batts in the fob and try to reattach them to the system? Its been a lot of disco3 things so my knowledge about as10 has gone black🙄
Im welding in the most rear left end chassipart, so the loom wont be affected. Land Rover owner since 2003 2008 Disco3 manual 2000 Defender 130 td5 snorkel warn m6000 |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5256 ![]() ![]() |
i am sure you can get battery isolators, that auto repairers use.
When i have done welding on my rover metro and my dads landy and mine. We have always disconnected the battery. Also it shouldnt harm your immobililizer. I have replaced my battery in my fob, as i use the central locking system than the key system. Never had to re sync anything at all, after i changed the batteries ![]() In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
