Home > Wheels & Tyres > Wolf rims
SGH
Wolf rims
I have on order a new 130 that comes with wolf rims and one of my first mods will be to change these for alloys. Will I have to replace all the wheel studs as the Wolf one are 60mm long ??
Simon
Post #96967 29th Oct 2011 5:52pm
kingofthesparks
Location: Very close to Watford gap services , northants
United Kingdom 2012 Defender 90 Puma 2.2 HT Fuji White
are you sellings wolfs ? Whistle
and tyres Whistle
Post #96969 29th Oct 2011 6:14pm
SGH
Yes selling all 5 but I have moved delivery date now to 1/3/12 993 Varioram - Guards Red
Defender 2.5 300TDI 110 HCP - Keswick Green
Defender 2.2 TDCI 130 HCP - Orkney Grey - GONE
Discovery 4 SDV6 HSE LUX - Corris Grey/Black Pack - GONE
Discovery 4 SDV6 HSE LUX - Montaciano Red/Black Pack - GONE
Post #96971 29th Oct 2011 6:18pm
kingofthesparks
1st dibs if the price is right please Thumbs Up
Post #96972 29th Oct 2011 6:19pm
22900013A
Didn't think there were any alloys capable of taking the weight of a 130, hence why you can't order them with them on? 2011 110 USW
1973 Series III 1-Ton
1969 IIA 1-Ton
1966 IIA 88"
Post #96974 29th Oct 2011 6:23pm
kingofthesparks
think zu are fine tuv rated
Post #96975 29th Oct 2011 6:24pm
SGH
Zu-rim, Terrafirma rims are... 993 Varioram - Guards Red
Post #96985 29th Oct 2011 6:40pm
K9F
Re: Wolf rims
SGH wrote:
Will I have to replace all the wheel studs as the Wolf one are 60mm long ?? Simon
Nuts too probably. I went the opposite way to you going from alloys to steel. Here is the advice I got....Hope this helps...Just read it backwards... Laughing
AndrewS wrote:
Looking Cool there Thumbs Up
However you may have an issue with your nuts Shocked I was told to use standard steel wheel nuts not the Ally type nut with Mach5s. This is nothing to do with dissimilar metals causing electrolyses. Its the design of the nut.
The steel nut is designed to pull up into the chamfer of the wheel, whereas the nut for the ally wheel is designed to pull up on the shoulder or washer. I also think that the chamfer of the ally type nut is different to the the chamfer in the steel wheels. The only reason for the chamfer on the ally type nut is to aid the fitting of the nut.
Please dont think I'm being a stick in the mud with this, just want you to be safe Thumbs Up
You can get galvanised steel wheel nuts cheap as chips Thumbs Up
Steel wheel nut
Alloy wheel nut
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #97012 29th Oct 2011 9:14pm
Blindos?
Post #97019 29th Oct 2011 10:17pm
22900013A
blackwolf wrote:
Blindos?
I take it thats an aftermarket rim? I'm not familiar with them as I have no wish to fit alloys to any of my vehicles, but I suppose some OM ones might be suitable, I just know Landrover ones aren't (in fact some won't even take a 110, eg Freestyles which were only ever on a 90)
My factory fit Wolf rims do not have the extended studs, I queried this and was told its perfectly fine and, as I say, thats how the factory fit them...will be interesting come MOT time in a couple of years. 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #97065 30th Oct 2011 10:50am
SGH
Any idea what offset the Wolf rim is ?? 993 Varioram - Guards Red
Post #97069 30th Oct 2011 11:06am
K9F
Just Googled it for you - 20.5mm! Both links seem to agree:
http://forum.landrovernet.com/archive/index.php/t-166529.html
http://www.d-90.com/forum/showthread.php?t=22938 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #97070 30th Oct 2011 11:18am
leeds
Zu Rims are rated at 1400kg, TUV approved.
If anyone is interested in them give one of your friendly site sponsors a bell/pm Laughing
Brendan
Post #97072 30th Oct 2011 11:39am
22900013A wrote:
blackwolf wrote:
Blindos?
Well, yes and no.
Fitted as standard to E-WMIK, R-WMIK, some Snatch, and some Wolf Defenders, so they are original factory fit. However only available to civvy buyers as aftermarket.
Fitted to the military vehicles above since they are actually the strongest Defender wheels currently available, stronger than the Wolf steel rims.
Quality comes at a price, as usual, and they are very expensive.
Post #97269 31st Oct 2011 11:53am
